Guest aperion Report post Posted 01/29/2008 09:20 AM Hello, i am having the same problem as the French person. I followed all the instructions and installed the unicode version. I saved the txt file in unicode but VG does not play anything. My configuration is as follow: - Dialogic analog card - SR 6 - VG 7 (it is supposed to be unicode, how can i check if it is the unicode version?) - Cepstral TTS with Vittoria italian voice If i do not save the tts txt file in unicode the system works without using accents. As you can see from the log i have the first message saved as regular text that is played while the second message called "terra1.txt" is unicode and i can not hear anything. Dear support team i cannot understand also why the system does not hang up. Calls stays up forever. 0129_1009_vgEngine.txt 0129_ktTel.txt 0129_ktTts.txt Share this post Link to post
SupportTeam Report post Posted 01/29/2008 11:48 AM Could you please post the terra1.txt file. We will the run it on our test system here and see how VoiceGuide reads that file and passes it to TTS. Share this post Link to post
Guest aperion Report post Posted 01/29/2008 12:17 PM QUOTE Could you please post the terra1.txt file. We will the run it on our test system here and see how VoiceGuide reads that file and passes it to TTS. It is unicode. terra1.txt Share this post Link to post
SupportTeam Report post Posted 01/30/2008 10:18 AM We have confirmed the file supplied by you does not work. We have opened that file and the saved it again in both UTF8 and Unicode format (attached). Both of the new files played fine. If you open the new _Unicode file in a Hex editor you will be able to see that it's structure is a bit different to the file which you have supplied. It has a couple extra bytes at the beginning which I think are used to identify the version of Unicode used to encode the file. Maybe you can use another editor to save your text in the Unicode format, or please try saving the files in UTF8 format instead. terra1_UTF8.txt terra1_Unicode.txt Share this post Link to post
SupportTeam Report post Posted 01/31/2008 02:43 AM QUOTE i cannot understand also why the system does not hang up. Calls stays up forever. We have found and corrected this bug. Please update to this version: [old link removed]. To update you will need to uninstall the current version, make sure no .EXE files are left in VG's main directory and then install the new version. Share this post Link to post
Guest aperion Report post Posted 01/31/2008 09:42 AM QUOTE i cannot understand also why the system does not hang up. Calls stays up forever. We have found and corrected this bug. Please update to this version: [old link removed] To update you will need to uninstall the current version, make sure no .EXE files are left in VG's main directory and then install the new version. Last question.My script says:- play the welcome message- if no asnwer play again message with a delay of 5 seconds- if timeout of 5 hang upThe problem is that VG does not play the message twice and that does not hangup.Any clue ? Share this post Link to post
SupportTeam Report post Posted 01/31/2008 11:08 AM Have you updated to the "_UnicodeTts2.exe." as per the previous post? Please post traces from your system which will let us see what is happening. Trace files are created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
