zikomandal Report post Posted 02/03/2008 11:16 AM I am using Voiceguide 7 now (migration from V 6). At voiceguide 6.0 I could change the scripts for a Dialogic port in runtime without changing the config.xml file in Data Folder. But is there any way of achieveing that in the interface of Voiceguide 7.0. Thank you for your support. Share this post Link to post
SupportTeam Report post Posted 02/03/2008 09:51 PM Easiest way too achieve this in v7 is to have the default starting script v7 be just a one module (and Evaluate Expression module) which does nothing else but to "GOTO" to another script. To change scripts you can just set a different script that this starting module "goes to". Share this post Link to post
