Guest skywalker Report post Posted 02/09/2008 01:53 PM hi i have modified ma script by putting a welcome "play sound file" module in the begining but the system insists to work from the module which was used to b the first module. So what u think ? Share this post Link to post
SupportTeam Report post Posted 02/09/2008 10:30 PM You need to specify that the new module is the new starting module for the script. In Script Designer go to the "Edit"->"Script Properties" menu to set the starting module, or right click on the button in on the module itself and select the "Make Start Module" option. Share this post Link to post
