Guest fmonroy Report post Posted 02/10/2008 09:11 PM Hello guys, I just noticed that VG7 needs .NET Framework 3.0 and when you install it, the speech applet from the control panel dissapears. I've some voices that work with VG5 thru SAPI 5.1. I bought 5 english and 2 spanish voices and wondering if they can work with the new V7 thru VoIP lines. Thanks in advance. FM. Share this post Link to post
SupportTeam Report post Posted 02/10/2008 11:33 PM In v7 the SAPI TTS voice used is specified in VG.INI. From http://www.voiceguide.com/vghelp/source/html/config_tts.htm : VoiceGuide v7 The default TTS voice is set in VG.INI, section [sAPI], field TTSEngine. eg: [sAPI] TTSEngine=Cepstral David-8kHz Share this post Link to post
