timwoolley Report post Posted 02/23/2008 12:37 AM I am having major problems with dialing out using VB.net 2005. I am attempting to que some calls then have then call when it is time. I am having success dialing an dcalling the numbers but my scripts die when attempting to access the database. I am sending data to the script via sRV and it appears to be parsing it incorrectly. This is a snippet from the log: 162435.578 8 1 db odbc RunOdbcQuery [Database Query 92], db=[], connect=[Driver={MySQL ODBC 3.51 Driver};DSN=xxxxx;Database=xxxxxr; User=dxxxxx;Password=xxxx;Option=3;], sql=[sELECT user_id FROM user_information WHERE user_id={5] it is parsing the RV wrong. I am sending it '[userID]{52}' as you can see from the vb code. It is getting a connection to the database just fine and everything else seems to be working OK but that one thing...... In the attached zipped file are 3 files. 1. Is the actual script I am attempting to run 2. a text file containing the vb code I am running from a vb .net 2005 app 3. log file Thanks Again, and I appreciate all of the help you give... VG_Trouble.zip Share this post Link to post
SupportTeam Report post Posted 02/23/2008 01:16 AM Please update to latest version which can be downloaded from our WWW. The latest version has this bug fixed. Share this post Link to post
