System Crashes
Using Windows ME - PII 266 - 96MB Ram
All up to date using VG5.0a and voice modem
The software seems to run fine at first. It works by answering the call and we could hear the voice on the phone.
Within some time, and it can be any point while the software is in use during a call, the system will suddenly crash and stop responding without warning or error. The system must be restarted.
We need a solution for this immeditly because this system has to be reilable.
There have been other reports of general problems with using modems on Windows95/95/ME systems.
The problems can usually be traced to modem drivers - some voice modem drivers are not very good - and Win95/98/ME have their problems as well.
Eg. see:
http://voiceguide.com/forums/index.php?showtopic=44
For a commercial system that needs to be on 24/7 you should use WinNT/2000 and a Dialogic card...
(how long does the system run on average before a problem occurring?)
I installed Windows 2000 on the same system to see if this solves the problem.
I installed the hardware drivers and it appears to be working correctly for the modem and sound card. I also installed the modem first.
I then installed the software VG5.0a and met all of the requirements. Allthough I will need a new reg# since the ID changed.
I setup and ran VG and encountered another problem. The modem answers and starts playing the greeting but all the sound prompts get cut off on the phone. I tried all the scripts provided and same thing happens. In other words, the modem answers, greeting will play and then cut off within the first couple of seconds.
Here is an example log but I don't think it provides any help.
110112.18 0 callstate OFFERING 65791 0 4
110112.18 0 ring 1
110112.18 0 Answer the call at 9/2/2003 11:01:12 AM
110112.18 0 lineAnswer(65791) => 65774
110112.19 0 callstate ACCEPTED 65791 0 0
110116.53 0 tapi Reply 65774 0
110116.53 0 callstate CONNECTED 65791,0,0
110116.54 0 WorkingModeTAPI=
110116.54 0 WorkingModeScript=
110116.54 0 Inband detection not enabled
110116.54 0 StartLoadedVgs at 9/2/2003 11:01:16 AM
110116.55 0 [say Recording] Playing
110116.55 0 tts generate start[Press 1, to begin recording your prompt. Press, pound, when finished.]
110116.89 0 tts generate end
110116.90 0 [say Recording] Playing (C:\Program Files\ivg\system\tts0.wav)
110116.95 0 PlaySoundStart ok [C:\Program Files\ivg\system\tts0.wav]
110116.95 0 RunModule PLAY end
110121.85 0 Play End line[0] (id=996600)
110121.85 0 LsPlayMsg EV_PLAY_FINISHED
110126.79 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
110126.79 0 tts generate reuse
110126.79 0 [say Recording] Playing (C:\Program Files\ivg\system\tts0.wav)
110126.86 0 PlaySoundStart ok [C:\Program Files\ivg\system\tts0.wav]
110131.75 0 Play End line[0] (id=6505)
110131.75 0 LsPlayMsg EV_PLAY_FINISHED
110136.68 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
110136.69 0 tts generate reuse
110136.69 0 [say Recording] Playing (C:\Program Files\ivg\system\tts0.wav)
110136.75 0 PlaySoundStart ok [C:\Program Files\ivg\system\tts0.wav]
110141.64 0 Play End line[0] (id=16399)
110141.64 0 LsPlayMsg EV_PLAY_FINISHED
110146.57 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
110146.57 0 tts generate reuse
110146.58 0 [say Recording] Playing (C:\Program Files\ivg\system\tts0.wav)
110146.63 0 PlaySoundStart ok [C:\Program Files\ivg\system\tts0.wav]
110151.53 0 Play End line[0] (id=26283)
110151.54 0 LsPlayMsg EV_PLAY_FINISHED
110156.15 0 callstate DISCONNECTED 65791,32,0
110156.15 0 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
110156.16 0 Hanging up call...
110156.16 0 RecSoundStop ok
110156.17 0 PlaySoundStop ok
110156.17 0 fnHangupCall end
110156.94 0 callstate IDLE 65791 0 0
110156.95 0 WorkingMode@Idle=
110156.95 0 tapi Reply 65757 0
110157.89 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
110157.89 0 ReinitTelephony due to IDLE start
110157.90 0 tapic lineDeallocateCall(MainCall:65791) 0
110158.50 0 lineOpen(0) => 0
110158.51 0 Waiting for a call...
110158.51 0 lineOpen(0)LineHandle=65740
It cuts off at "Press 1 to begin re..."
What's wrong now? Thanks
As you can see th trace shows that VoiceGuide issuing to the modems Wave drivers instructions to play the sound file in [say Recording] moduel a number of times - and the modem's wave drivers are correctly responding... if you are hearing just the first couple of seconds then looks like the Win2000 wave drivers for this modem are not doing what they say that they are doing...
I'd suggest checking with the modem manufacturer if they have any updated Win200 drivers, or trying another modem (or a Dialogic card...)
I bought a new modem based on the forum - Broadxent v.92 56k PCI
The new modem along with running Windows 2000 seems to fix that wav problem. However, as I was testing the scripts, I got an error that caused VG to stop.
The error:
Run-Time error '6':
Overflow
After I pressed ok, VG exited.
This only happened once and I was looking at the log and it was while loading the outgoing dialer numbers.
Any ideas? I'm trying to see if I can reproduce this.
Thanks.
Would of course be interested if you can find how this problem occurred (and/or how it can be reproduced) - I take it that you are using v5.0a as indicated before?
It may be a good idea to have in VG.INI:
[TraceLog]
LogToFile=1
Then VoiceGuide will continually write the trace log to: C:\VoiceGuideLogMMDD.txt and then the contents of that log can tell us what the system was doing when the problem occurred...
