BenCab Report post Posted 03/05/2008 11:32 PM Can somebody give me a step by step instructions as to how connect VoiceGuide to a Cisco Call Manager 4.2. Particulary the steps required on the Call Manager side. Thanks, Ben Share this post Link to post
SupportTeam Report post Posted 03/06/2008 12:35 AM Does your CallManager support SIP, or only H.323? Do the VoIP telephone handsets which are attached to it use SIP or H.323 to communicate with the CallManager? Share this post Link to post
BenCab Report post Posted 03/06/2008 07:07 PM The phones are currently configured as SIP Share this post Link to post
SupportTeam Report post Posted 03/06/2008 09:36 PM If the phones are configured as SIP then you should be able to add VoiceGuide to the system as other SIP extensions. Instructions on how to register SIP extensions are provided in the Help file. Please see: http://www.voiceguide.com/vghelp/source/ht...ip_register.htm You would need to configure the CallManager to setup the new extensions. I was however advised that CallManager 4.2 does not include SIP end-point support, only H.323. VoiceGuide can act like a H.323 endpoint as well, but it at this stage does not support H.323 features which facilitate 'auto-discovery' and 'auto-setup' type functionality, which is what the Cisco H.323 phones use when plugged into the network. You would need to setup the H.323 call routes manually. Share this post Link to post
adtsoft Report post Posted 03/20/2008 10:26 PM I can't find the answer I am looking for, but I have setup a ton of H323 gateways on CallManagers. Select Device / Gateway / Add a New Gateway. Gateway type: H.323 Gateway, Device Protocol: H.255, click Next. For the Device Name enter the IP of the device. For the Description use something that will make it easy to find and know what it is. For Pool select a Gateway. Set the Calling Search Space to a valid selection for your setup, typically User. Check Display IE Delivery and Redirecting Number ID Delivery - Outbound. Click Insert and then reset the Gateway. Share this post Link to post
Guest tafelzeil Report post Posted 03/27/2008 10:44 AM Aaron, We had same problem, reinstalling the HMP drivers did the job. See earlier post. Jos I can't find the answer I am looking for, but I have setup a ton of H323 gateways on CallManagers. Select Device / Gateway / Add a New Gateway. Gateway type: H.323 Gateway, Device Protocol: H.255, click Next. For the Device Name enter the IP of the device. For the Description use something that will make it easy to find and know what it is. For Pool select a Gateway. Set the Calling Search Space to a valid selection for your setup, typically User. Check Display IE Delivery and Redirecting Number ID Delivery - Outbound. Click Insert and then reset the Gateway. Share this post Link to post
SupportTeam Report post Posted 03/27/2008 10:38 PM I think the thread referred to by tafelzeiltje is here: http://voiceguide.com/forums/index.php?showtopic=5214 Share this post Link to post
