Wav File Being Cut Off
Tonight I was testing a new script, when it plays the welcome wave file, its getting cut off - the first 1/2 second so welcome sounds like elcome.. If you play the file by itself its fine. How do I add a slight pause. Should I record a blank wav file? or add a wait in a vbs in my script.
Thanks. We have many wav files from Allison and this is the only one with it being cut off.
Paul
C3msWelcome.wav
0314_0007_vgEngine.txt
Some Telcos do not connect the voice path immediately after call is answered, but up to about half a second later - that is why sometimes the beginning of the first sound file played immediately after call is answered is not heard by caller.
The solution is to insert some silence at beginning of the file, or play a short silence wav before playing the welcome message.
