Digital Card
which card should i used for 4 lines only and its will be go inside PBX and support VGs v7 , windows xp ?
D/4PCIUF is usually the card used. The D/41JCT has some extra features that allows the system to perform "Dial and Conference" (Tromboned) transfers.
i need to connect dialogic card to pbx extenions line which model card should i use ?
The D/82JCT can connect to some PBX Digital extensions. Which PBX are you using?
The usual approach is to connect the Dialogic card to the PBX's Analog extensions.
