Error Database Db Query
192435,26 6 state [Database] DB Query
192435,26 6 db ODBC mode used name:[sridesa] connect:[ODBC;DSN=gvp;UID=genesys;PWD=genesys]
192435,74 6 db About to execute a Retrieve type operation [select CCE_PCK_SERVICIO_GENESYS.FUN_RESULTADO_LISTA_BLANCA ('1708723489001') from dual]
192435,82 6 db [Database] row count=1
192435,82 6 rv add [Database_RowCount]{1}
192435,82 6 db get RecordsetGetRowsMax
192435,82 6 db get 999 records. (row count=1)
192435,82 6 db update RVs
192435,82 6 ERROR 6.0.3379 RunModule line=5940, 13:Type mismatch:VoiceGuide
0320vgm.txt
What Database is VoiceGuide connecting to?
What is the type of the CCE_PCK_SERVICIO_GENESYS.FUN_RESULTADO_LISTA_BLANCA field?
Can you tell us how you resolved the problem?
Did you change the type of the database field?
Many ODBC drivers cannot return data in fields that are of type "BLOB" or other similar fields designed to store large data chunks.
