era Report post Posted 04/01/2008 10:54 AM Dir Sir I setup Voice Guide software and run but face a problem. I send a pictue that contains problem. This error show "Run-time error '339'. Component 'ktTel.ocx' or one of its dependencies not correctly registered: a file is missing or invalid" Please reply. From Md. Arifur Rahman Share this post Link to post
SupportTeam Report post Posted 04/01/2008 11:04 AM Most likely the Dialogic drivers have not been installed. Please install the Dialogic drivers and ensure the Dialogic service is started before installing VoiceGuide. Share this post Link to post
era Report post Posted 04/02/2008 10:04 AM Dir Sir I setup Voice Guide software and run but face a problem. I send a pictue that contains problem. This error show "Run-time error '339'. Component 'ktTel.ocx' or one of its dependencies not correctly registered: a file is missing or invalid" Please reply. From Md. Arifur Rahman I am not use Dialogic Card. I am use SmartUSB56 Voice Modem. This is same error. Please reply. From Md. Arifur Rahman Share this post Link to post
SupportTeam Report post Posted 04/02/2008 11:20 AM VoiceGuide v6 only works with Dialogic cards. If you have a voice modem then you must use VoiceGuide v5. A Dialogic cards will give better results then a voice modem. Most voice modms are unreliable. Share this post Link to post
