Outbound Dialing Problems
Dear Sir
I also use Dial for Outbond dialing but face a problem. Dial my mobile number and I also saw message in VG but this dial can't go in mobile. I send a picture.
Plz send
From
Md. Arfiur Rahman
The screenshot shows the system operating normally. Please describe in more detail what you are encountering. Trace Logs capturing the call would be useful here.
Dear Sir
What is the mean 'Trace Logs capturing' ? Is there any relation for Outdail with "Voicemail Manager" and "Phone Manager" ? How can I use 'Dialer_OutDialQueAdd' in VBScript ? Plz send example. I am not see "OutDial_New.xml" in \data directory.
What is the affect "<OutDialEntry>" in "OutDial_New.xml" file.
Plz reply all question.
With regards
Md. Arifur Rahman
In v7 the trace logs are automatically created in VG's \log\ subdirectory.
In v6 the trace logging needs to enabled like this:
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=10
ktTts=0
There is an example in the Help file.
The OutDial_New.xml is a file that you would create is that's how you wish to load the calls. Please read the relevant section of the Help file.
It's part of the required format of the "OutDial_New.xml" file...
Dear Sir
I send attachment file. Any relation with "Voicemail Manager" and "Phone Manager" for outdial call purpose ? I am so happy for last relpy. Its so fast.
Plz reply.
With regards
Md. Arifur Rahman
Log.zip
Trace shows 3 outbound calls being made by the system, but 2 of the calls were ended when the Dialogic card detected a busy signal on the line, and on one of the calls the Dialogic card could not detect and ringback so it assumed the outbound call connected, and it then started the script.
When using analog Dialogic cards you will need to precisely set the Busy, Ringback, Disconnect etc tones in VoiceGuide's ConfigLine.xml file so that the Dialogic card can correctly determine what is happening on the line. See: http://www.voiceguide.com/vghelp/source/ht...ctiondetect.htm
102512.22 1 dial making call tel[9,01715733577] ann[NONE] vgs[G:\Person.vgs] am[G:\Machine.vgs] OnHangup[] rv[none[OutDial_ID]{194}[OutDial_OnNotConnected]{}[OutDial_AnswerTimeout]{60}[Ou
Dial_RetriesLeft]{2}[OutDial_PauseBetweenRetries]{60}]
102518.23 1 tw DialogicEvent 133,TDX_CALLP,7,0,0,CR_BUSY,,
102518.23 1 event BUSY, iCode=133 state=5200
102527.25 2 dial making call tel[9,01715733577] ann[NONE] vgs[G:\Person.vgs] am[G:\Machine.vgs] OnHangup[] rv[none[OutDial_ID]{195}[OutDial_OnNotConnected]{}[OutDial_AnswerTimeout]{60}[Ou
102550.64 2 tw DialogicEvent 133,TDX_CALLP,9,0,0,CR_NORB,,
102550.64 2 event NORINGBACK, iCode=133 state=5200
102652.27 1 dial making call tel[9,01715733577] ann[NONE] vgs[G:\Person.vgs] am[G:\Machine.vgs] OnHangup[] rv[none[OutDial_ID]{196}[OutDial_OnNotConnected]{}[OutDial_AnswerTimeout]{60}[Ou
102658.30 1 tw DialogicEvent 133,TDX_CALLP,7,0,0,CR_BUSY,,
102658.30 1 event BUSY, iCode=133 state=5200
No. Those two apps do not set or affect anything related to outbound dialing.
