Dialer_outdialqueadd Errors With Variable Phone Number
I was using the Dialer_OutDialQueAdd subroutine in a VBS module.
I kept getting type-mismatch errors, even though I was feeding it a string for the phone number (as the help file seems to suggest)
I reduced it down to just the barest functional elements and still get this error. Here's the code in question:
phoneNumber = "18183046281"
vg.Dialer_OutDialQueAdd phoneNumber, 0, 0, 0, "", "4", 1, "", "C:\Program Files\VoiceGuide2\Scripts\catch_call_test.vgs", "C:\Program Files\VoiceGuide2\Scripts\catch_call_test.vgs", "[thisActivity]{1}", 0, 2, 5, "C:\Program Files\VoiceGuide2\Scripts\no_one_home.vgs",""
vg.Run_ResultReturn $RV_LINEID, phoneNumber
set vg = Nothing
WScript.Quit
I've tried converting the value to a string, even as other data types, but it always gives me a type-mismatch error. I've even tried dimensioning the variable.
Am I missing something here?
Voiceguide 6.0.3003
Dialer: 6.0.2003
It should be noted that when I put the string directly in, it adds it correctly. It only gives me this problem when I use a variable.
I've scoured the web for vbscript help, and tried various ploys, but all seemed to result in the same outcome.
Voiceguide 6.0.3003
Please update to the latest version ov VG v6 - available for download from our WWW Download pages. Then use the demo provided in the Help file's section on Dialer_OutDialQueAdd as a test first.
Voiceguide 6.0.3003
Updated to 6.0.3379
Same result.
Specific error message:
Script: C:\Program Files\Voiceguide2\temp\vbs_4_1.vbs
Line: 7
Char: 1
Error: Type mismatch: 'vg.Dialer_OutDialQueAdd'
Code: 800A000D
Source: Microsoft VBScript runtime error
Specific code in question:
set vg = Nothing
WScript.Quit
Error logs pertinent section:
141737.52 4 next module is [Queue_Next_Calls] (idx=23)
141737.52 4 RunModule start [Run VB Script,[Queue_Next_Calls],23,,]
141737.52 4 timer clear bForceClear=False
141737.52 4 state [Queue_Next_Calls] Running VB Script...
141737.52 4 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
set vg = Nothing
WScript.Quit
141737.52 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide2\system\voice\}[PathApp]{C:\Program Files\VoiceGuide2\}[PathDataVm]{C:\Program Files\VoiceGuide2\data\}[PathVgSys]{C:\Program Files\VoiceGuide2\system\}[thisActivity]{2}[OutDial_ID]{99}[OutDial_OnNotConnected]{}[OutDial_Answer
imeout]{60}[OutDial_RetriesLeft]{2}[OutDial_PauseBetweenRetries]{120}[OutDial_Re
ult]{Contacted_AM}[AmWelcMsg_RecLen100ms]{42}[scriptEnd_Time]{4/29/2008 2:17:37 PM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide2\Scripts\voicesolutions.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{4/29/2008 2:17:37 PM}[scriptStart_CalledFrom_Module]{Queue_Next_Calls}[scriptsPath]{C:\Program Files\VoiceGuide2\Scripts\}[scriptPath]{C:\Program Files\VoiceGuide2\Scripts\}[Activity_Select_RowCount]{1}[Activity_Select_1_1]{2}[Activity_Select_2_1]
1}[Activity_Select_3_1]{8183046281}[Activity_Select_4_1]{0}[Activity_Select_5_1]
352-644-1512}[Activity_Select_6_1]{4/14/2008 2:03:03 PM}[Activity_Select_7_1]{1}[Activity_Select_8_1]{1}[Activity_Select_9_1]{4/4/2008}[Activity_Select_10_1]{12:00:00 AM}[Activity_Select_11_1]{4/14/2008}[Activity_Select_12_1]{10}[Activity_Select_13_1]{3}[Activity_Select_14_1]{1
[Activity_Select_15_1]{4/14/2008 2:03:03 PM}
141737.52 4 vbs run [vbs_4_1.vbs], cmd [wscript "C:\Program Files\VoiceGuide2\temp\vbs_4_1.vbs" //I //T:60]
141737.58 4 Run Script waiting. iRunWait=1 (shellid=1860, process=1512)
I used the version from the new helpfile, and that seemed to work.
The difference between what I tried and what was in the help file was that I used cstr before, when I populated the variable, and the helpfile used it within the subroutine argument. I guess it's more like a cast than an actual function (cstr, that is)
I see you guys caught the thing about "escalation level" not actually being "optional" in the "don't put anything" sense of the word :D
I'm retrofitting my production code with the modification now.
Thanks!
