Vbs Module
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("C:\111.txt", ForReading,True)
StrConnStr=tsFile.ReadAll
tsFile.Close
set tsFile = Nothing
set fso = Nothing
if Err.Number <>0 then
Else
vg.RvSet $RV_LINEID, "ConnString", StrConnStr
End If
Set vg=Nothing
When running this script in module vbs in the begging of script it fails
i want to retrieve connection script from separate file when begging the script and putting it in variable
i can read connection string from file before open connection with database but these require to wirte the above code with each vbs module using to connect to database
HINT: This script tested successfully with vbs editor
what is the mistak?????????
The script looks fine and there is nothing wrong with using a VBScript module as the starting module of your script.
How does the script fail? What are the error messages if any that you see or what is shown in the VoiceGuide traces?
Please post some traces from VoiceGuide showing the incoming call.
If you have any Anti-Virus software installed then please remove it. Antivirus software can interfere with VBScript execution.
Ok Log Files Is attached
i use vg v7 and i begging the script with VBS module and in case of success got to welcom module
in fail goto hangup Module , the script goto to hangup module
Log.zip
The traces show why the VoiceGuide script ends. The VBScript is not returning a result to VoiceGuide, so VoiceGuide takes the fail path to the module in your script titled [Hangup the Call 2], which ends the call.
You should modify your script to use the Run_ResultReturn command, like this:
Then the Success path will be taken.
Add the Run_ResultReturn line to just before the Set vg=Nothing call.
Ok Thanks It is Now Working
But I have one more Question
in say number module voice guide look for sound files in the directory where it is installed (i.e files 1.wav,....)
can i change the directory of these sound files
because i want to gather my own script files in one location far from insttalation folder
