Guest badawy200379 Report post Posted 05/05/2008 08:58 AM First i would like to thank all supportteam members for powerfull support i want to transfer call to ip telephone what steps to be done to achieve that Share this post Link to post
SupportTeam Report post Posted 05/05/2008 12:43 PM If you want to use VoIP then the best approach is to use v7 of VoiceGuide and run it on HMP VoIP drivers. Otherwise you would need to use an extern al Media Gateway to convert the Analog (or T1/E1) lines to VoIP. Share this post Link to post
