New To Voiceguide
Hi all im new to VoiceGuide and currently evaluating it. Im running code as below VBScript to perform a lookup on a dabase table.
Set vgoCommandLink = CreateObject("vgServices.CommandLink")
Set conConnection = CreateObject("ADODB.Connection")
Set recRecordSet = CreateObject("ADODB.Recordset")
' Open connection to the database
conConnection.Open "Driver={SQL Server};Server=RFSQL1;Database=RFLIVE;Uid=sa;Pwd=password;"
' Sql to execute
strSQL = "SELECT Name FROM Engineers WHERE EngineerId = 1661"
' Get a recordset of data
recRecordSet.Open strSQL, conConnection
If Not (recRecordSet.EOF) Then
   EngineerName = recRecordSet.Fields(0).Value
End If
' Return success or failed code
vgoCommandLink.Run_ResultReturn $RV_LINEID, "[EngineerName]{" & EngineerName & "}"
Set vgoCommandLink = Nothing
Set cmdCommand = Nothing
Set conConnection = Nothing
Set recRecordSet = Nothing
This executes fine the next box is an evaluator to check if a string was returned the expression to evaluate is $RV[EngineerName] I have the following paths
on {true} goto [PlayEngineerName]
on {false} goto [PlayEngineerNotFound]
and I have ticked 'Store results in log file' to check if the script above is working. In the log file the result is shown but in the evaluation on false only ever gets executed. What am I doing wrong?
Also can you get multiple results from a script into the $RV? I have tried RvSet in the script but didn't seem to work
Many thanks
Andy
I see that you need to place quotes around as its a text variable.
Andy
Yes, quotes are needed in the Evaluate Expression module if the $RV is a string.
Please let us know if you have any other questions.
