sladuke Report post Posted 05/14/2008 05:39 AM I am working on an announcement only setup. I had everything working. I am not sure what changed. On future calls, no sounds was heard. I have uninstalled and reinstalled DIALOGIC HMP 3.0 (199) and VG v7.05. I am using Trixbox between VG and my SIP Trunk provider. With VG stopped, I can successfully make calls with sound using X-LITE from the same computer that VG is running on. I am using a licensed version of VG. Attached are all of the files I could think of, except the large WireShark capture, which I do have. Any ideas? Should I attach the capture? Thanks, Steve. Problem_zip.zip Share this post Link to post
SupportTeam Report post Posted 05/14/2008 06:11 AM If you would like for the outgoing script to start immediately after the outgoing call is answered then you need to set the "Answering Machine" script to: DISABLE Trace shows the outgoing call was being made, and when the call was answered VoiceGuide started the "Live Person / Answering Machine" Detection/Discrimination. Looks like the person answering the call did not say anything (usually they would say "Hello" or something similar) so the Dialogic card just waited for 20 seconds - after which Dialogic timed out and told VoiceGuide to start the "Live Person" script, which VoiceGuide did. Setting the "Answering Machine" script to DISABLE will result in .vgs script started immediately after answer. 214426.406 9 3 state Dialing 914152255170@192.168.1.6 Ringing... 214426.421 9 3 LsWaitAfterDialingOut : 2081,GCEV_ALERTING,2081,0,0,,, 214436.484 9 3 ev CallState sEvent=LINECALLSTATE_CONNECTED, crn=0x8000001, iEvent=2 ,256,0,,,] 214436.484 9 3 callstate: CONNECTED crn=0x8000001,ev=2,LINECALLSTATE_CONNECTED,2,0 214436.484 9 3 Set_hCall crn=0x8000001, called from LINECALLSTATE_CONNECTED 214436.500 9 3 LineEvCallState_Connected_OutBound crn=0x8000001, WorkingModeScript= 214436.515 9 3 dial wait as LineState().sCallProgressOption=[DX_PAMDOPTEN] 214436.515 9 3 state Dialing 914152255170@192.168.1.6 Ringing..., doing answer detection... (DX_PAMDOPTEN) 214456.531 9 3 ev Dialogic 133,TDX_CALLP, crn=0x8000001 (134217729), 9,0,0,CR_NORB,, 214456.531 9 3 LsWaitAfterDialingOut : 133,TDX_CALLP,9,0,0,CR_NORB,, 214456.546 9 3 rv add [$RV_STARTTIME]{2008-05-13 21:44:56} 214456.546 9 3 rv add [$RV_DEVICEID]{3} 214456.546 9 3 rv add [DlgcVoice]{dxxxB1C1} 214456.546 9 3 rv add [DlgcNetwork]{iptB1T1} 214456.546 9 3 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 214456.546 9 3 rv ScriptsPath could not be set as LineState[iLineId].iVgsIdx = 0 in StartLoadedVgs_InitLineState 214456.546 9 3 rv add [$RV_CALLEDNUMBER]{914152255170@192.168.1.6} 214456.546 9 3 Set_hCall crn=0xe8b15, called from OnCallAnswered_StartScript_Human Share this post Link to post
sladuke Report post Posted 05/14/2008 02:57 PM If you would like for the outgoing script to start immediately after the outgoing call is answered then you need to set the "Answering Machine" script to: DISABLE Trace shows the outgoing call was being made, and when the call was answered VoiceGuide started the "Live Person / Answering Machine" Detection/Discrimination. Looks like the person answering the call did not say anything (usually they would say "Hello" or something similar) so the Dialogic card just waited for 20 seconds - after which Dialogic timed out and told VoiceGuide to start the "Live Person" script, which VoiceGuide did. Setting the "Answering Machine" script to DISABLE will result in .vgs script started immediately after answer. ... I should have also stated that the answer detection stopped working too. Before the message would start playing sooner. Now the answer detection does not sense a voice and waits to play the .WAV file. When the .WAV file is played, no audio is heard. It seems like a two-way audio failure. Share this post Link to post
SupportTeam Report post Posted 05/14/2008 09:06 PM We'll need to see the WireShark trace to see if Voice is being transmitter/received. Please start the WireShark trace and restart VoiceGuide The load a new call with the "Answering Machine" script set to: DISABLE After answering the call please say a few words (regardless of whether you can hear anything else played on the line or not) Please post VoiceGuide traces and the complete WireShark trace. Share this post Link to post
sladuke Report post Posted 05/23/2008 05:28 PM Sorry for the slow reply. I was having an unrelated issue with my VOIP provider. I recorded a short message and disabled the answering machine with the word "DISABLE". I had voicedial make a test call. I answered the call and said "hello" several times. I did not hear the message. I captured all network traffic with Wireshark. All files involved are in the attached ZIP file, including the .WAV file. Thank you for your help! --Steve. vg_no_sound_zipped.zip Share this post Link to post
SupportTeam Report post Posted 05/23/2008 10:50 PM Can you please post the VgEngine and ktTel traces for this call as well please. We can then see what is happening on VoiceGuide's side at the same time as the WireShark trace capture is made. Share this post Link to post
sladuke Report post Posted 05/24/2008 05:03 AM Can you please post the VgEngine and ktTel traces for this call as well please. We can then see what is happening on VoiceGuide's side at the same time as the WireShark trace capture is made. I'm sorry I missed them. They are in the attached file. Thanks again, Steve. log_files.zip Share this post Link to post
SupportTeam Report post Posted 05/24/2008 08:29 AM When you press DTMF tones on the telephone handset are they reported as being heard by VoiceGuide? Share this post Link to post
sladuke Report post Posted 05/25/2008 07:16 PM No, VoiceGuide cannot hear touch-tones. (I am using rfc2833 for touch-tones.) Share this post Link to post
sladuke Report post Posted 05/28/2008 05:28 PM I would also like to point out that after this problem started, I completely replaced the hardware that VoiceGuide was running on. The problem followed. Could the problem be related to the fact that the SIP Register fails? I am having problems figuring out how to get VoiceGuide to register with my Trixbox server. Even though it doesn't register, Trixbox accepts connections because of the IP address. Share this post Link to post
SupportTeam Report post Posted 05/28/2008 09:02 PM The WireShark traces show that no sound is being sent out, even though the Dialogic HMP driver is reporting that the sound data is played. We have not seen this issue before, so we are going to try to replicate your system setup as best as we can to see if we can replicate the problem. Can you please tell us about what hardware are you using (motherboard/CPU etc) and against which version of Trixbox are you registering with. Are you able to hear VoiceGuide playing if you just make a call directly into the VoiceGuide system by just dialing it's IP address directly? Share this post Link to post
sladuke Report post Posted 05/28/2008 09:31 PM Here is the first page of SysInfo: OS Name Microsoft Windows XP Professional Version 5.1.2600 Service Pack 2 Build 2600 OS Manufacturer Microsoft Corporation System Name VG3 System Manufacturer Dell Computer Corporation System Model OptiPlex GX240 System Type X86-based PC Processor x86 Family 15 Model 1 Stepping 2 GenuineIntel ~1495 Mhz BIOS Version/Date Dell Computer Corporation A05, 7/19/2002 SMBIOS Version 2.3 Windows Directory C:\WINDOWS System Directory C:\WINDOWS\system32 Boot Device \Device\HarddiskVolume1 Locale United States Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" User Name VG3\Administrator Time Zone Pacific Daylight Time Total Physical Memory 1,024.00 MB Available Physical Memory 444.45 MB Total Virtual Memory 2.00 GB Available Virtual Memory 1.96 GB Page File Space 2.40 GB Page File C:\pagefile.sys Note: The complete SysInfo is attached. sysinfo.zip Share this post Link to post
sladuke Report post Posted 05/28/2008 11:38 PM Note: I hope to test the inbound SIP call tomorrow. Share this post Link to post
sladuke Report post Posted 05/30/2008 04:42 AM VoiceGuide would indicate that a call was incoming, but it would not answer it. I have a feeling that my problems are related to the failure of VoiceGuide to successfully register with Trixbox. Does anyone use VoiceGuide & Trixbox? Is there a sample Trixbox Extension configuration? It looks like Trixbox does not support MD5 secrets. (Asterisk does, but not the FreePBX GUI that Trixbox uses.) Should I be switching to just plain Asterisk, without the Trixbox front-end? I am begining to think that I should not have spend $796 for this VoiceGuide product that I cannot use. Share this post Link to post
SupportTeam Report post Posted 05/30/2008 05:30 AM First we should establish is the system is functioning properly on it's own and then we can look the VoIP registration side. Have you tried testing VoiceGuide by just dialing into it directly using the IP address of the machine on which VoiceGuide is installed? Just run this test before you try setting up any VoIP PBX registration options VG. Just use VG as it is when it is first installed and dial into it. You can also test outgoing calls by dialing your VoIP (soft)phone directly from VG. Can the sound be heard then? Run the WireShark traces on VG's system at the same time when making the two tests above. Please ensure no other VoIP related programs are running on this system apart from HMP and VoiceGuide. This will let us confirm VoiceGuide's operation and we can then move onto registering it with Trixbox or Asterisk and fixing that configuration. I assume that Trixbox was installed on another machine, correct? We have other users using VoiceGuide with Asterisk with no problems. Share this post Link to post
