Guest Henry Report post Posted 02/10/2003 03:58 AM Is there any way to have the program go to different modules at different times of the day or different days? For example, instead of transferring a call after closing, it re-directs to a .wav module telling them to call back during business hours? Share this post Link to post
SupportTeam Report post Posted 02/10/2003 06:40 AM You can use the Evaluate Expression module to swtich to different parts of script based on time/date. From VoiceGuide Help file: Example I Switch to different parts of the script based on Day / Time. Use the $RV_DAY, $RV_DATE, $RV_HOUR and $RV_MINUTE Result Variables. To switch all calls on Saturday and Sunday you can use the $RV_DAY as the expression to be evaluated, and then in your Paths text box you can type: On {6} Goto [Play Saturday message] On {7} Goto [Play Sunday message] Another way to do this is to use the following expression: ($RV_DAY = 6) or ($RV_DAY = 7) and then in your Paths text box you can type: On {True} Goto [Play Weekend message] Example II To Play one message during business hours, and one outside business hours of 8:30am and 5:30pm you can use the following expression: ($RV_DAY >= 1) and ($RV_DAY <= 5) and ( (($RV_HOUR >= 9) and ($RV_HOUR <= 17)) or (($RV_HOUR = 8) and ($RV_MINUTE >= 30)) or (($RV_HOUR = 17) and ($RV_MINUTE < 30)) ) and then in your Paths text box type: On {True} Goto [Play Business Hours message] On {False} Goto [Play After Business Hours message] Share this post Link to post
