Ring The Phone
Hi!
is it possible to make voice guide ring the phone again?
Example:
To leave a message press 1
To send and email press 2
To hang-up this call press 3
To talk to an operator press 0
When pressing 0, the phone will ring.
Is there also a way to integrate fax to this software?
Rather the ringing the handset a sound file should be played over the PC speaker:
VG's Help file section on the Run Program Module has information on how to play a sound file over the PC speaker, the command line is (for example):
sndrec32 /play /close c:\test.wav
please see:
http://voiceguide.com/forums/index.php?showtopic=464
VoiceGuide can be used to implement a fax-back system (pleas see Help file's entry o RUN VBScript module) but it cannot receive faxes itself, and there are no fax applications which would accept a handed off fax call these days...
