Adding Fields To Output
Hi Support Team
I am currently using using vg5 and it gives me output as a csv file xml file and vgl file. The output is very much standard. Suppose i want to add another field to my output for example i want to dial number 8973545, supplier X, i want voice guide to output
<DNIS>8973545</DNIS><supplier>X</supplier>, ....
where supplier is the new field i have added to voice guide output in the vgl file
will appreciate your help
You can use an Evaluate Expression module to have information saved in the script's call log file. Just add an Evaluate Expression module to the script and then have a look at the new script call log entries.
