How Many Call Can A Server Handle
What is the maximum amount of calls that can be handled simultaneously, configuring the software to work without any cards just on a internet connection using a decent server and a fast internet connection , what are the limiting factors , how many servers would be required for 50 lines all in use at the one time?
Joe
HMP VoIP drivers are rated for up to 600 channels when using a fast computer/server (Xenon based CPU). The line limit depends more on what your application does during the call: the complexity of the database interactions for example.
To successfully deploy VoIP you need to ensure that the connection between your computer/server and the VoIP provider will not drop/delay any VoIP packets.
