Guest joefromireland Report post Posted 06/10/2008 07:06 PM What is the maximum amount of calls that can be handled simultaneously, configuring the software to work without any cards just on a internet connection using a decent server and a fast internet connection , what are the limiting factors , how many servers would be required for 50 lines all in use at the one time? Thanks Joe Share this post Link to post
SupportTeam Report post Posted 06/10/2008 09:00 PM HMP VoIP drivers are rated for up to 600 channels when using a fast computer/server (Xenon based CPU). The line limit depends more on what your application does during the call: the complexity of the database interactions for example. To successfully deploy VoIP you need to ensure that the connection between your computer/server and the VoIP provider will not drop/delay any VoIP packets. Share this post Link to post
