Guest joefromireland Report post Posted 06/25/2008 07:21 PM Can I use cable to test a four line trial system. These are the details from my voip supplier What do i need to do to test the system out From other VoIP users: 320721@blueface.ie From normal telephones: +353-1-5242025 extn: 320721 Thanks Joe Share this post Link to post
SupportTeam Report post Posted 06/25/2008 09:34 PM You can try setting up a multiple line VoIP based system to function over cable/ADSL, but it’s not advisable as in such setups you do not usually have guaranteed bandwidth and will see packet loss and/or delay. Before making calls over the Cable/ADSL try placing calls into system by just directly dialing its IP address from softphone or VoIP handset on the same LAN. This will confirm for you if the system is working. You can then try setting up your router/gateway/etc to accept/make VoIP calls over the cable/ADSL. Share this post Link to post
