Error With Hpm Install
What effect will this error have on the install of HPM
the messsage is The local APIc timer is incompatible with this release the set up program will now disable the dialogic HPM API
thanks
Joe
HMP Documentation says that it has minor effect, but in practice we found that users who have this problem are unable to run HMP if they see this error.
What CPU and Motherboard is used on this system?
I am useing a Dell D600 laptop to test the system witha 2 gig mobile processer I dont rember geting the error the first time I installed the program but i did get it when I reinstalled the program.
You can try running the system and see what happens, but it may be a good idea to try doing this on another system.
