KReidy Report post Posted 06/27/2008 07:55 PM Could somebody please help me, I am trying to run the attached script without much success!!! I have inserted admin tracelog throughout the script but I am not receiving any of these in the log file (also attached) I have tested another script to see if the tracelog was set up properly and it is. The script retrieves a number from an excell spreadsheet , returns it to the script via a variable that plays a message. I hope someone will point me in the right direction. VoiceGuideScript.txt VoiceGuideLogFile.txt Share this post Link to post
SupportTeam Report post Posted 06/27/2008 11:20 PM You have a call using xlApp before xlApp is created. Try removing this line: xlApp.DisplayAlerts = False To test VB scripts just save them in the .vbs file and try running them by double clicking on the file, you will then see any error messages. Dim xlApp, xlBook, xlSht Dim filename, value1, value2 filename = "c:\Test\Test1\test.xls" Set vg = CreateObject("vgServices.CommandLink") xlApp.DisplayAlerts = False vg.Admin_TraceLogAdd 0, 0, "**** calling CreateObject Excel.Application" Set xlApp = CreateObject("Excel.Application") ... Share this post Link to post
KReidy Report post Posted 06/28/2008 12:52 AM Thank you very much I did as you said and it is working now. Share this post Link to post
