Guest Panos Report post Posted 07/01/2008 08:19 PM Sometimes the program open after 3rings, other 4, other 5,other 10 other never .; Thanks for your help log.zip Share this post Link to post
SupportTeam Report post Posted 07/01/2008 10:34 PM The trace shows that all the calls were answered immediately when a "Ring" event was reported by the TAPI device that you are using (VoiceLink-X). There are many calls in the trace, which call are you referring to? Please provide the time of the call. Also, you are doing SQL queries which result in a large amount of data returned to VoiceGuide. This would slow the v5 of VoiceGuide down (v7 guards against this and is not slowed down by large database queries) One SQL query that we can see that you are doing is: SELECT * FROM GOODS ORDER BY PRODUCTID DESC You should change this to select either only those entries that you want. Have a look at the trace to see the time this query takes to process and the amount of data that is imported int VG from the Database and then stored in VoiceGuide's $RVs Share this post Link to post
Guest Panos Report post Posted 07/02/2008 07:12 AM is v7 supports Voie Link board? Share this post Link to post
SupportTeam Report post Posted 07/02/2008 07:15 AM Quote is v7 supports Voie Link board? No. Share this post Link to post
