Guest joefromireland Report post Posted 07/13/2008 10:02 PM Can you mix and match you requirments on V7 to have most of the lines on the enterprise and say two of the 40 have dialer module fitted. Also how long does it take to verify credit card I am think of buying a few lines to try it out you may respond by email if you wish too this question . thanks for the quick responce to the last question Share this post Link to post
SupportTeam Report post Posted 07/13/2008 11:26 PM It is not possible to mix different license types on the same system. The licenses are issued on a 24 hours turnaround basis. Processing of orders usually takes less then 24 hours. Share this post Link to post
BluePlanet Report post Posted 07/19/2008 01:58 AM This is going to be an issue for me too. I want to run a large system but it is 99 percent incoming. I only need to make a few outgoing calls and maybe will use a few lines for that at any time. Paying an extra $100 per line seems to be very expensive for a small thing. Is there any reason I could not buy both types of licenses if I ran them each on separate boxes? Share this post Link to post
SupportTeam Report post Posted 07/19/2008 06:00 AM Is there any reason I could not buy both types of licenses if I ran them each on separate boxes? You can have two different licenses on two separate boxes. Share this post Link to post
