Guest Panos Report post Posted 07/16/2008 05:12 PM Hello; I am running VG version 5.2.5049 prof. Edition single line license. The program constantly crashes. We are using Voice Link 2L pci board and Win Xp Thanks 0716sw.txt 0716tw.txt 0716vgm.txt Share this post Link to post
SupportTeam Report post Posted 07/17/2008 12:22 AM After looking at the traces we can see that the traces so not show any system crashes. On both occasions VoiceGuide was exited after the "Exit" Command button was pressed by user... What is the error message that you are seeing on the screen? Can you post a screenshot? Also please note that many TAPI drivers are not reliable. For a professional system you should look at getting a Dialogic card and using VoiceGuide v7. Share this post Link to post
Guest Panos Report post Posted 07/17/2008 11:29 AM This is the screenshot. Thanks again __959___954_.zip Share this post Link to post
SupportTeam Report post Posted 07/17/2008 09:10 PM Screenshots show that the error is occurring in the MSJET40.DLL, which is the dll used in the MS Access database interactions. Please ensure you have the latest Microsoft patch for the MSJET40.DLL. Microsoft information about this can be found here: http://support.microsoft.com/kb/239114 We'd recommend updating to the latest MDAC (Microsoft's Data Access Components) that will run on your system - see: http://msdn.microsoft.com/en-au/data/aa937729.aspx Also please note that many TAPI drivers are not reliable. For a professional system you should look at getting a Dialogic card and using VoiceGuide v7. Share this post Link to post
