$rv[dirsystemvoice] And Callerid Problem
The Problem is
When i initialized the $RV[DIRSYSTEMVOICE] variable at the begging of the script with directory path to refer to when saying wav file
still looking in voiceguide directory
and caller id is nothing although i have callerid in my handset phone and the service is provided from my company
i posted the log and the script which i use to test poth problem
I wish i have response soon
thanks
ScriptAndLog.zip
In the captured call at no stage where any system sound files actually used, so value of $RV[DIRSYSTEMVOICE] was never even used.
Do you know what protocol your Telco uses to transmit CallerID? Which Telco is providing these lines?
Sorry ,
I donot Understand First response
i want to know what happen when i initialize $rv[dirsystemvoice] at the begging of script
when i assign wave file to modules without full path just name of wave it should go where [voice guide directory OR new initialized path]
actually i donot know what protocol used But the company is Saudi Telecom
$RV[DIRSYSTEMVOICE] specifes the location of "system" sound files. The ones that are usually located in \system\voice\ subdirectory. These sound files: http://www.voiceguide.com/vghelp/source/html/soundfiles.htm
If you do not specify the path VG will look in the scripts directory, or in script's \voice\ subdirectory.
Thanks For Replay
It Now Clear thanks
But i want to ask
is there is no predefined tones [disconnected , Busy....]for different types of PBX or most used centrals in the world
