Guest badawy200379 Report post Posted 08/04/2008 10:18 AM This is the model of our PBx which we use to transfer calls from Voice guid to internal extension [Nesco mode no.288] i wish i find tone setting for it [busy,Disconect,.....etc Tones] thanks Share this post Link to post
SupportTeam Report post Posted 08/04/2008 10:53 AM Instructions on finding out the tones played on any analog line and how to then set the Config.xml appropriately can be found here: http://www.voiceguide.com/vghelp/source/ht...ctiondetect.htm Share this post Link to post
Guest badawy200379 Report post Posted 08/04/2008 11:06 AM Ok Thanks i will try it but i have one more question i have problem with callerid and when i searched forum i found that the problem was solved by sending [ktTel.ocx,ktTelControl.ocx] and when i searched these two files i didnot find them in my system32 sub directory note , i use voiceguide 7.6 with dialogic SR6 Share this post Link to post
SupportTeam Report post Posted 08/04/2008 11:29 AM VoiceGuide version 7 does not use the files you mention. Those files are used by version 6 of VoiceGuide. Share this post Link to post
