Simple Call Transfer
I'm having hard time to execute this script (attached). Basically I have to call a number, play a wav file and then transfer to this extension 5010.
If I use the option Dial out and Conference than it works. But the option Im trying to use is Hookflash Blind. The weird thing is that I was testing several different configurations and there was a time that worked and then stopped working??
I have Dialogic cards and Televantage Phone system. The PBX command strings has "!" as the dial function to transfer. The string that I know it works from my regular phone is "**1" and then the extension.
Attached also the VG.INI and other log files.
Should I update my voice guide engine/program? Please help me out.
Thank you
Alex
Data.zip
Many PBXs/Switches do not allow hookflash transfers on outgoing calls, only on incoming.
You may need to use the Dial and Conference on the outgoing calls.
Ok, but I dont want to use 2 lines to do it.
Do you have another suggestion?
Thank you,
Alex
If the PBX does not support hookflash transfers then your only option is to use a "2-line" (Dial and Conference / Tromboned) transfer.
