Phone Line Q And Os Question
Hi: 2 Quick questions
1. Can VoiceGuide run on a 64bit Version of Win2003 Server?
2. Does 24 volt vs 48 volt phone lines make a difference?
Have not tested it and not sure if Dialogic drivers are certified for the 64 bit Win2003.
Why do you want to use the 64 bit version?
Either is fine. From what I understand most Telcos use 48V and most PBXs use 24V. Dialogic cards are certified to work with both.
