Get Numbers Always Fails
Hi
Ever since we retrieved a licence the Get Numbers module always enters the fail-path even though it shouldn't.
The script worked fine until now. We've made no changes to it (that I know of).
With a verification like this (just to test):
set Link = CreateObject("vgServices.CommandLink")
Link.Run_ResultReturn $RV_LINEID, "verify_passed"
set Link = Nothing
And paths like this:
on {*} goto [Login]
on {success} goto [LoginQuery]
on {fail} goto [LoginFailed]
on {timeout 10} goto [LoginExit]
The script still always enters the LoginFailed state.
I've attached the script and log (zipped).
TravelLog.zip
To use VBScripts you need to have the Enterprise (or Evaluation) license of VoiceGuide.
Perhaps you are currently using the Professional license?
If you still have problems please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened.
