SupportTeam Report post Posted 08/14/2008 09:11 PM hisoft wrote: I am working on building IVR System to receive and process voice calls. Does VoiceGuide supports Dialogic boards such as D/300PCI-E1 and Diva® PRI/E1-30? Do you suggest another PCI card that I can use with PRI/E1 line (30 channels) and supported by VoiceGuide? Share this post Link to post
SupportTeam Report post Posted 08/14/2008 09:21 PM For a single PRI E1 site you would need to use a Dialogic D/300JCT card. See: http://www.dialogic.com/products/tdm_board...0JCT_Boards.htm D/300PCI-E1 is an older card that is no longer supported by the current Dialogic drivers. For a list of other Dialogic cards which work with VoiceGuide please see our Recommended Hardware page. Share this post Link to post
BluePlanet Report post Posted 08/15/2008 03:48 AM I thought the current Dialogic driver release 6.x just dropped support for ISA boards. Is there a list somewhere of what PCI boards support has been dropped for? Thanks. Share this post Link to post
SupportTeam Report post Posted 08/15/2008 05:08 AM In the SR6.0 Release Notes there is a list of which boards are supported. Boards not on that list are not supported. You can double check whether D/300PCI is supported by looking in the Release Notes PDF file. Our understanding is that it is not. Share this post Link to post
