svitex Report post Posted 08/14/2008 10:15 PM In VoiceGuide 7.0.6 with Dialogic Card D41JCTLS (analogic). I prefer to use the Dialout and Conference because it's possible to play on Hold sound file. For sample, this is my config in the Transfert module : Phone : 200 Transfert : Dialout an conference - Monitored. On Hold File : wait.wav Line to use : 2 Bridge calls together when : "Voice is detected. Listen for disconnect tones. (DX_PVDOPTNOCON)" Announce message : announce.wav Paths : on {fail} goto [HOME] I call with the line 1. I hear the wait music and the line 2 ring. I pick up the phone on the line 2 and i say "YES". The line 2 hang up immediately. The line 1 take the fail path. Best regards ktTel.txt vgEngine.txt Share this post Link to post
SupportTeam Report post Posted 08/15/2008 11:29 AM The version which can be downloaded using the following link fixes this bug:[old link removed]Please note that this new version uses a DLL to generate the SayNumbers .WAV lists. To change it use the VBScript (lib_num2wav.vbs) approach you will need to have this entry in VG.INI file:[moduleSayNbrs]WavListGenerator=VBScript Share this post Link to post
