Caller Id Important
i have problem with caller id
when searching i found that our telecim company use CALLER ID standard [DTMF]
i am in saudi arabia
is these format supported in voiceguide
or what can i do to retrieve caller id??????????
thanks
Does the telephone company send the CallerID as DTMF immediately after the call is answered (similar to ‘Inband Signaling’ approach) or between the 1st and 2nd ring (before the call is answered)?
Have you used a CallerID detector to confirm CallerID is sent on this line?
i use telephone machine which display caller id from these line
Please i have problem in contacting with this person who reponsible in Telecom Company no one give me answer
i nedd the solution in both cases
thanks
I tested VoiceGuide with intel Dialogic Card d/41JCT in Saudi Arabia country, it's working but after two rings at least.
khalid tammam
Saudi Arabia, Jeddah
k_tammam@yahoo.com
At what stage does the telephone that you use displays the CallerID? Between 1st and 2nd ring or only after call is answered?
So just to confirm, the CallerID is always displayed by your telephone device immediately when the second ring starts ringing, correct?
Could you please post a copy of VoiceGuide's Trace Logs which captures the system startup and the incoming call, this will allow us to see what happened.
Please post the traces.
Two calls on the same line please. ie: restart, place call , hangup and then palcfe another call. We'd like to see the traces from two calls on same line.
