SupportTeam Report post Posted 09/10/2008 09:46 PM JohnnyV wrote: My problem is very similar to newpop1's problem as described at: http://voiceguide.com/forums/index.php?showtopic=5652 (except I am using your "Say Number" module to speak back the access query value as opposed to TTS). My question to the Support Team is: "Is newpop1's solution of separating the "Play before saying the number" WAV file from the "Say Number" module into its own "Sound File" module the solution that Katalina is recommending for this problem? Thank you. JohnnyV Share this post Link to post
SupportTeam Report post Posted 09/10/2008 09:53 PM The recommended solution is to have your own sound files recorded in the correct format. Once your sound files are in the correct format then you will be able to play them as part of the Play numbers module in conjunction with the system sound files. See: http://www.voiceguide.com/vghelp/source/html/soundfiles.htm Share this post Link to post
