Transfer Call
VoiceGuide 7.0.7
In Record Module, the Filename to Recorded can be like this :
REC-TECH-$RV[sOCIETE]-[$RV_LINEID]-$RV[NbRecTech].wav
But in the Transfert Module there is no possibility to use variables in filename for the announce message.
Could you make a new version or a patch for that ?
Thanks.
Could you please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened.
Trace files are created in VG's \log\ subdirectory.
