Busy Signal
Troubleshooting:
View Event Trace Log
142859.03 0sys cleanup start
142859.05 0sys cleanup end
First time user of system. Need assistance to figure out why busy signal when you call system
Does the telephone line work? If you plug that telephone line into a telephone handset does the telephone handset ring when you dial the telephone line's number?
Does the card answer calls when you use the sample applications that come with the Dialogic drivers?
If it does not then you should be contacting the card supplier to resolve this problem.
