teidetelefonica Report post Posted 09/12/2003 08:58 PM PLEASE , I NEED AN AUTOMATIC IVR SYSTEM TO COLLECT INFORMATION VIA DTMF , SEND IT VIA-IP TO A REMOTE COMPUTER. MAY WORK ON DIALOGIC 4-8-16 ANALOGUE LINES. ANY SUGGESTION??? THANKS IN ADVANCE DIEGO BELLAFIORE TEIDETELEFONICA@WANADOO.ES Share this post Link to post
SupportTeam Report post Posted 09/13/2003 12:05 AM This can be done using VoiceGuide. The information collected in a Get Numbers module is stored in a Result Variable. (see Help file for more info on this, online page of help file is here: http://www.voiceguide.com/vghelp/html/modG....dGetNumber.htm) Then you can send this information by using a socket control from a Run VB Script module (http://www.voiceguide.com/vghelp/html/modVbs.htm) Code to send data by TCP below: Dim oSck Set oSck=CreateObject("MSWinsock.Winsock","sck_") 'In that way you can handle events. with sck_ functions at end of code 'fill in port and IP address. oSck.RemotePort = oSck.RemoteHost = oSck.Connect 'event handlers... Sub sck_Connect Msgbox "connected" oSck.SendData "place data to send here" End Sub Sub sck_SendComplete oSck.close Msgbox "send complete, connection closed" End Sub (if you need to use UDP you would set upi connection like this:) Const sckTCPProtocol = 0 Const sckUDPProtocol = 1 With oSck .Protocol = sckUDPProtocol ' Set the control to UDP protocol. .RemoteHost= "PeerB" ' name of the other computer. .RemotePort = 1001 ' Port to connect to. .Bind 1002 ' Bind to the local port. End With Dialogic cards are fine (we recommend them as the preferred hardware to use with VocieGuide) - please see: http://www.voiceguide.com/suppRecomHardware.htm Share this post Link to post
Guest Guest_TEIDETELEFONICA Report post Posted 09/30/2003 03:30 PM TKS , VERY MUCH FOR YOUR SUPPORT, FIRST STEP: 1) I BUILD A SCRIPT TO CAPTURE NUMBERS , WORKS GOOD AS GOOD ARE WAV FILES! (VG IS VERY INTUITIVE) BUT I CAN'T UNDERSTAND OR FIND ,WHERE THE INFORMATION IS STORED!?! 2) IF THE INFORMATION COMES FROM 3 DIFFERENT "GET NUMBERS MODULES",IS POSSIBLE TO STORE IT IN ONLY 1 FILE , TO SEND IT , VIA IP AS UNIQUE GROUP OF DATA? P.S. IS # SET AS DEFAULT TO INDICATE TO THE GET NUMBER THE SEQUENCE IS FINISHED? THANKS IN ADVANCE DIEGO BELLAFIORE Share this post Link to post
SupportTeam Report post Posted 09/30/2003 10:55 PM BUT I CAN'T UNDERSTAND OR FIND ,WHERE THE INFORMATION IS STORED!?! Please read the "Result Variables" section of the Help file. 2) IF THE INFORMATION COMES FROM 3 DIFFERENT "GET NUMBERS MODULES",IS POSSIBLE TO STORE IT IN ONLY 1 FILE , TO SEND IT , VIA IP AS UNIQUE GROUP OF DATA? Yes - you would just concatenate the three Result Variables together. P.S. IS # SET AS DEFAULT TO INDICATE TO THE GET NUMBER THE SEQUENCE IS FINISHED? Yes. * functions the same - unless there is a "On {*}" path defined... Share this post Link to post
