Sql Express 2005
We are using VG 7.0.6. Having trouble with the connect string using SQL Express 2005. In another post you state there is an example of the connect string in the VG Help file. I cannot find this example. Can you provide me with an example of the connect string? Thank you.
In the v7.0.6 Database Query module you would need to setup the ODBC connection to the SQL Server. The connection string example is in the Help file. See the "ODBC Data Source (MSSQL)" entry.
