Guest mhsamei Report post Posted 10/20/2008 10:43 AM Hi I Write an ASP page to insert and update OutDialQue.mdb. I put This statement iv RV field : [test]{121121}[test2]{110110} In the Script I try to Use These tow RVs But HoW? In My VBS Run Module I Use These Eample (from VG Help): Example 1 Running from an external application set vg = CreateObject("VoiceGuide.CommandLink") 'see how long the call on line who's LineID is 6 has been going on for: sReturnValue = vg.RvGet($RV_LINEID, "$RV_test") set vg = Nothing MsgBox sReturnValue Example 2 Running from VoiceGuide's VB Script module set vg = CreateObject("VoiceGuide.CommandLink") 'see how long the call on current line has been going on for: sReturnValue = vg.RvGet($RV_LINEID, "RV_test") set vg = Nothing MsgBox sReturnValue In Example 1 befor "RV" we see "$" but in example 2 not? How Can i ge and Use Dialer RVs in my script? Share this post Link to post
SupportTeam Report post Posted 10/20/2008 11:09 AM If you are using VoiceGuie v7 then please try: sReturnValue = vg.RvGet($RV_LINEID, "test") And this should work in all v5/v6 and v7 : sReturnValue = vg.RvGet($RV_LINEID, "RV[test]") but it's simplest to just use: $RV[test] in the script directly, like this: sReturnValue = "$RV[test]" Which version of VoiceGuide are you using? BTW. MsgBox will not work from VoiceGuide v7. For debugging/tracing VBScripts in VoiceGuide v7 use Admin_TraceLogAdd : http://www.voiceguide.com/vghelp/source/ht...tracelogadd.htm Share this post Link to post
Guest mhsamei Report post Posted 10/20/2008 12:17 PM Thank You. Solved. I use Vg 5. Wth Your Older Pacth for Analog Dialogic. I Use Dialog/4. again Thanks. Share this post Link to post
