Skipping Intro Module
I have a simple 4 question survey with intro and closing thankyou modules. I cannot get the intro to play, it skips directly over to the first question. I tested the wave file and it is fine. The path has the following:
on {timeout 0} goto [Question1]
It skips it every time. I just want it to play the wave file and go directly to question 1.
Thanks,
Laurel
Is the 'Start' module of the script set properly?
See the Edit->Script Properties menu in the Script Designer.
If you still have problems:
Trace files are created in VG's \log\ subdirectory.
