Unable To Log Data.(logging Problem0
Hi
I am trying to write the following data i.e., LineID,CallerID etc., and few more data to the log trace.
I viewed all the the log files but unable to get the data in trace file/log file.
This is the script which i am using as the start module.
I have also add the vgs file to the .
sThisScript = "leave msg.vgs"
sThisModule = "LmRecInit"
function ldgz(ByVal N) ' N presumed integer
if (N>=0) and (N<10) then ldgz= "0"+Cstr(N) else ldgz=Cstr(N)
end function
Yr = Year(Now) : Mo = ldgz(Month(Now)) : Dy = ldgz(Day(Now))
Hr = ldgz(Hour(Now)) : Mi = ldgz(Minute(Now)) : Sc = ldgz(Second(Now))
sDateTimeStamp = Mo & Dy & Hr & Mi & Sc
'above is the alternate way of getting a Timestamp rather the using VGs Result Variables.
iLineId = $RV_LINEID
sFname = "$RV[TheOtherLoginID]_$RV[LoginID]_" & sDateTimeStamp & "_1_" & iLineId & "_.wav"
Set vg = CreateObject("VoiceGuide.CommandLink")
vg.Admin_TraceLogAdd 0, 0, "APMIP Data before RV_DEVICEID"
iDeviceId = $RV_DEVICEID
vg.Admin_TraceLogAdd 0, 0, "APMIP Data before RV_CIDNUMBER"
iCallerID = $RV_CIDNUMBER
'iLineId = $RV_LINEID
vg.Admin_TraceLogAdd 0, 0, "APMIP Data before RV_STARTTIME"
iStartTime = $RV_STARTTIME
vg.Admin_TraceLogAdd 0, 0, "APMIP Data"
vg.Admin_TraceLogAdd iLineId, 0, "APMIP Data"
vg.Admin_TraceLogAdd iLineId, 0, iStartTime
vg.Admin_TraceLogAdd iLineId, 0, iDeviceId
vg.Admin_TraceLogAdd iLineId, 0, iCallerID
vg.Admin_TraceLogAdd iLineId, 0, iLineId
sNewRv = "[LmRecFilename]{" & sFname & "}"
sRet = vg.Run_ResultReturn(iLineId, sNewRv)
Set vg = Nothing
I am also attaching the trace file and vgs file. I am unable to get these details in Trace
What my task is wen I recive the call I have to run a script and
in which I have to create a folder with the callerID and dstarttime combination,
after the script i will be asking few question to the caller and record the responses and save these files into this folder.
At the end I have to save this callerId and call time/starttime and folder location into MySql Database.
please help me.
1024_1910_vgEngine.txt
1024_1913_vgEngine.txt
leave_msg.vgs
Some of the modifications you made to the script may stop it from running. You should add Admin_TraceLogAdd calls from the beginning of the VBScript and track the scripts progress to see if it stops executing at some stage due to error in script.
Hi
I have modified the script as below.
even now i could not get the first line into the log/trace.
vg.Admin_TraceLogAdd 0, 0, "APMIP Data start"
end function
'Set vg = CreateObject("vgServices.CommandLink")
Set vg = Nothing
I am also attaching the vgs and the tracefile.
I have the following setting in vg.ini
[Log]
;Automated "log-to-file" logging.
;To turn OFF logging for a particular application set it's entry to 0
;To turn ON all logging for a particular application set it's entry to 10
;all log files are saved in VoiceGuide's \log\ subdirectory
;Log files are named as follows:
;VoiceGuide : MMDD_HHNN_vgEngine.txt
;ktTel : MMDD_ktTel.txt
;ktTts : MMDD_ktTts.txt
VoiceGuide=10
NumberLoader=0
ktTel=10
ktTts=0
;uncomment below to stop any Script-relates logs (*.vgl/*.csv/*.xml)
;from being created as each script is executed.
;Scripts=OFF
;set CDR_LastData_SaveRv to 1 to save in the CDR record the RVs created during the call
CDR_LastData_SaveRv=0
1027_1119_vgEngine.txt
leave_msg.vgs
I don’t think the VBScript you quoted is a valid VBScript.
To check what VBScript is ran by VoiceGuide you can lookup the filename in the vgEngine trace.
The trace supplied shows that the VBScript was saved in C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs and was ran from there.
Suggest you just double-click on the C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs file (you can do this while VoiceGuide is running) and see if any error messages get displayed. If there is an error you will be told on what line the error occurred.
If you have problems with VBScripts then the best way to approach them is to start with a simple VBScript, confirm that it works and then add to it bit by bit confirming that it works after each addition.
eg. start with just this:
vg.Admin_TraceLogAdd 0, 0, "This trace was printed from an external VB Script"
set vg = Nothing
112013.437 18 7 state [LmRecInit] type: VB Script, iRunWait=2
112013.468 18 7 rv replace start (strlen>500)
112013.468 18 7 rvns: [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{C:\Chatline\scripts\}[scriptsPath]{C:\Chatline\scripts\}[$RV_STARTTIME]{2008-10-27 11:20:13}[$RV_DEVICEID]{7}[DlgcVoice]{dxxxB1C4}[DlgcNetwork]{dxxxB1C4}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\Chatline\scripts\}
112013.468 18 7 script will be ran from file: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
112013.468 18 7 delete existing: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
112013.500 18 7 current objVbsOrExeProcess=
112013.500 18 7 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs][] timeout=60 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
112013.500 18 7 objVbsOrExeProcess.Start call
112013.625 18 7 RunVBScriptFile just started. Handle=34016, Id=5788, StartTime=10/27/2008 11:20:13 AM, HasExited=False
112013.625 18 7 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs], ProcessHandle=[34016], VbsOrExeProcess.WorkingSet=[90112]
Hi
Thanks Now i can trace the data.
I opened the file and ran directly , i got few error and i modified them and the problem resolved, indeed waht you said was correct there were error in the script,
