Why It Thinks The Other Side Is Fax, How To Catch The Event
We are using analog line, and the card is D4PCI-UF (D41JCT-LS). (voiceguid v6). Please take a look at the attached log segment. I don't know why it thinks the other side is fax. The phone rings and I pick up. But no expected messages, since the card thought it's a fax machine. We have two cards in the system and both have same problem. If we can't do anything to the phone signal, I am wondering if I can pick up the condition and do some program and the program can continue, otherwise it hang and the server seems dead.
Please help.
Ronghui
190428.52 2 state Waiting for a call...
190430.72 2 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
190430.72 2 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
190430.72 2 setting iDialoutReadyToDialout = 1
190440.25 2 dial [789,99338104,810291904,0,2359,MoTuWeThFrSaSu,[],1,c:\toa\callout\UGI_trial\1651152.wav,c:\toa\callout\UGI_trial\ugi_trial1.vgs,c:\toa\callout\UGI_trial\ugi_trial1.vgs,[PhoneNumberCalled]{99338104}[TOAID]{1260}[JOBID]{117}[First
Name]{Vincent}[LastName]{Yarmel}[Jobdesc]{Building Maint.}[FillCount]{2}[Token]{init}[CallBackPhone]{14089971698},29,0,5,c:\toa\callout\UGI_trial\ugi_notcon.vgs,] (search started at 190440.25)
190440.25 2 dial DialOnLine start tel[99338104] ann[c:\toa\callout\UGI_trial\1651152.wav] vgs[c:\toa\callout\UGI_trial\ugi_trial1.vgs] am[c:\toa\callout\UGI_trial\ugi_trial1.vgs] rv[[PhoneNumberCalled]{99338104}[TOAID]{1260}[JOBID]{117}[FirstName]{Vincent}[La
stName]{Yarmel}[Jobdesc]{Building Maint.}[FillCount]{2}[Token]{init}[CallBackPhone]{14089971698}] cid[]
190440.25 0 dial callque update id=789: NextCallTime=0810291909(10/29/2008 7:09:40 PM), RetriesLeft=-1
190440.25 2 rv clear all
190440.25 2 rv add [PhoneNumberCalled]{99338104}
190440.25 2 rv add [TOAID]{1260}
190440.25 2 rv add [JOBID]{117}
190440.25 2 rv add [FirstName]{Vincent}
190440.25 2 rv add [LastName]{Yarmel}
190440.25 2 rv add [Jobdesc]{Building Maint.}
190440.25 2 rv add [FillCount]{2}
190440.25 2 rv add [Token]{init}
190440.25 2 rv add [CallBackPhone]{14089971698}
190440.25 2 rv add [OutDial_ID]{789}
190440.25 2 rv add [OutDial_OnNotConnected]{c:\toa\callout\UGI_trial\ugi_notcon.vgs}
190440.25 2 rv add [OutDial_AnswerTimeout]{29}
190440.25 2 rv add [OutDial_RetriesLeft]{0}
190440.25 2 rv add [OutDial_PauseBetweenRetries]{5}
190440.25 2 dial making call tel[99338104] ann[c:\toa\callout\UGI_trial\1651152.wav] vgs[c:\toa\callout\UGI_trial\ugi_trial1.vgs] am[c:\toa\callout\UGI_trial\ugi_trial1.vgs] OnHangup[C:\toa\callout\UGI_trial\ugi_onfinish.vgs] rv[[PhoneNumberCalled]{99338104}[TOAID]{1260}[JOBID]{117}[FirstName]{Vincent}[La
stName]{Yarmel}[Jobdesc]{Building Maint.}[FillCount]{2}[Token]{init}[CallBackPhone]{14089971698}[OutDial_ID]{789}[
OutDial_OnNotConnected]{c:\toa\callout\UGI_trial\ugi_notcon.vgs}[OutDial_AnswerTimeout]{29}[OutDial_RetriesLeft]{0}[OutDial_
PauseBetweenRetries]{5}]
190440.25 2 script interpretor: VgMulti v6.0.3386
190440.25 2 state Dialing 99338104
190440.27 2 lineMakeCall=>[]
190440.27 2 timer set 39 EV_TIMEOUT_MAKECALL_NORESPONSE
190440.81 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
190440.81 2 event TDX_SETHOOK, iCode=135 state=5200
190440.81 2 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
190500.88 2 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
190500.88 2 event FAX, iCode=134 state=5200
190500.88 2 LsWaitAfterDialingOut : 134,FAX,191,0,0,DE_TONEON,FAX,
190500.88 2 event TDX_CST, iCode=134 state=5200
190500.88 2 LsWaitAfterDialingOut : 134,TDX_CST,191,0,0,DE_TONEON,FAX,
190500.89 2 tw DialogicEvent 133,TDX_CALLP,18,0,0,CR_FAXTONE,,
190500.89 2 event CR_FAXTONE, iCode=133 state=5200
190500.89 2 LsWaitAfterDialingOut : 133,CR_FAXTONE,18,0,0,,,
190500.89 2 event TDX_CALLP, iCode=133 state=5200
190500.89 2 LsWaitAfterDialingOut : 133,TDX_CALLP,18,0,0,CR_FAXTONE,,
190500.89 2 DialoutProcessFailedDial start sCalledFrom=[LsWaitAfterDialingOut-CR_FAXTONE] RetriesLeft=0
190500.89 2 rvns add [OutDial_Result]{Uncontactable_FaxAnswer}
190500.89 2 timer clear bForceClear=False
190500.89 2 OnNotConnected unknown app [c:\toa\callout\UGI_trial\ugi_notcon.vgs]
190500.89 2 dial no escalation info
190500.89 2 HangupCall start (CR_FAXTONE in LsWaitAfterDialingOut)
190500.89 2 rv add [Hangup Time]{10/29/2008 7:05:00 PM}
190500.89 2 state Hanging up call... [CR_FAXTONE in LsWaitAfterDialingOut]
190500.89 2 HangupCall_Common hCall=0
190500.89 2 play PlayStop ok
190500.89 2 timer set 1 EV_TIMEOUT_DOLINEDROP
190500.89 2 state Waiting for a call...
190500.89 2 fnHangupCall end
190500.89 2 tw DialogicEvent 134,TDX_CST,3381,0,0,DE_LCON,,
190500.89 2 event TDX_CST, iCode=134 state=900
190500.89 2 LsAwaitingCalls EV_UNKNOWN_134
190501.97 2 timer fired EV_TIMEOUT_DOLINEDROP
190501.97 2 event EV_TIMEOUT_DOLINEDROP, iCode=9102 state=900
190501.97 2 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
190501.00 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
190501.00 2 event TDX_SETHOOK, iCode=135 state=900
190501.00 2 LsAwaitingCalls EV_UNKNOWN_135
190501.00 2 event callstate IDLE 2 1,0,0
190501.00 2 WorkingMode@Idle=
190501.00 2 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
190501.00 2 timer clear bForceClear=True
190501.00 2 LineState(iLineId).iVgsIdx = 0
190501.00 2 timer set 0.3 EV_TIMEOUT_TIMETOREINITLINE
190502.30 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
190502.30 2 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
190502.30 2 init atidle reinit : start
190502.30 2 init atidle reinit iConferenceOtherLegLid=-1
190502.30 2 init atidle reinit : reset all LineState variables
190502.30 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
190502.30 2 state Waiting for a call...
190504.50 2 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
190504.50 2 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
190504.50 2 setting iDialoutReadyToDialout = 1
So when you say "Hello" or similar the Dialogic card reports it as a fax machine?
You may want to try changing the fax tone definition in the ConfigLine.xml file to something that is unlikely to be detected, eg:
<Tone Name="Call Progress Tone TID_FAX1">
<Notes>undetectable</Notes>
<ID>TID_FAX1</ID>
<Freq1>3000</Freq1>
<Freq1Dev>50</Freq1Dev>
<Freq2>0</Freq2>
<Freq2Dev>0</Freq2Dev>
<On>1000</On>
<OnDev>10</OnDev>
<Off>0</Off>
<OffDev>0</OffDev>
<Count>10</Count>
</Tone>
<Tone Name="Call Progress Tone TID_FAX2">
<ID>TID_FAX1</ID>
<Freq1>3000</Freq1>
<Freq2>0</Freq2>
<On>1000</On>
<OnDev>10</OnDev>
<Off>0</Off>
<OffDev>0</OffDev>
<Count>10</Count>
</Tone>
The ktTel trace of the whole call would better show us what is going on here. ie. what were the current TID_FAX1/TID_FAX2 settings and which one was detected etc.
Feel I'd better ask instead of figuring out myself. KtTel trace is at bottom. On 190500.889 002, it's determined the other side is FAX. Our configLine.xml for fax is as following also: Use your fax line configuration will eliminate the problem?
<Notes>Default Setting</Notes>
<ID>TID_FAX1</ID>
<Freq1>2150</Freq1>
<Freq2>0</Freq2>
<On>25</On>
<OnDev>25</OnDev>
<Off>0</Off>
<OffDev>0</OffDev>
<Count>1</Count>
</Tone>
<ID>TID_FAX2</ID>
<Freq1>1100</Freq1>
<Freq2>0</Freq2>
<On>25</On>
<OnDev>25</OnDev>
<Off>0</Off>
<OffDev>0</OffDev>
<Count>1</Count>
</Tone>
190423.842 002 ocxfn PlayStart(hLine=2, strSoundFile=[C:\toa\ugivoice\UGI_Callout_Voice\64732745.wav], lPlayId=730031(0xb23af), lParam1=0, lParam2=0, strParam1=, strParam2=, keys[NotUsed])
190423.842 002 ocxfn PlaySetControlKeys(2,0,,,,,,,,,,)
190423.842 002 ocxfn PlaySetControlKeys end
190423.842 002 play start (hli=0x1d2c30, strSoundFile=C:\toa\ugivoice\UGI_Callout_Voice\64732745.wav, lPlayId=730031(0xb23af), lParam1=0, lParam2=0, strParam1=, strParam2=)
190423.842 pcm sample_bytes=2, data_size=32000 _
190423.842 pcm data_size_div2=16000, ptrVoiceData_Current=0xb967ad0
190423.858 fread 16001 pcm16 bytes
190423.858 iReadCount test 16001
190423.858 iFilesQueued test 1
190423.858 002 buffer workaround (15999) (2 bytes truncated from end of each file)
190423.905 002 dlgc dx_clrsvcond(2) => 0
190423.905 002 wFileFormat=8, (pcm=8, adpcm=1)
190423.905 002 iott 0xb965ee8 io_type=0xc, io_fhandle=0, io_bufp=0xb96f7e8, io_offset=0, io_length=15999, io_nextp=0x0, io_prevp=0x0, rfu=0x0
190423.905 002 dlgc play(2, 0xb965ee8, 0x0, 0x1d6120, EV_ASYNC) call
190423.905 002 dlgc play(2, 0xb965ee8, 0x0, 0x1d6120) => 0, hli=0x1d2c30
190425.967 002 gc_GetMetaEvent returned. iDev=0, lEvtType=2, pEvtData=0x81, lEvtDataLen=86719760
190425.967 002 ev TDX_PLAY (Play Completed)
190425.967 002 cleared dwPlayId: hli=0x1d2c30, hli->dwPlayId=0(0x0)
190425.967 002 ocxev PlayEnd(dwLineId=2, dwPlayId=730031)
190425.967 002 ocxev DoFireDialogic(dwIdx=797, 2, 129, [TDX_PLAY], 730031, 0, 0, [], [], []) (dwIdx=797)
190425.967 002 ocxev DoFireDialogic completed
190425.967 002 ocxfn PlayStop(hLine=2, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
190425.967 002 dx_stopch call in PlayStop
190425.967 002 dx_stopch 2 ok
190427.030 002 ocxfn LineDrop(sLineId=2, , lParam1=0, lParam2=0, strParam1=, strParam2=0)
190427.030 002 dx_sethook(2) call
190427.030 002 dx_sethook 2 DX_ONHOOK ok
190427.061 002 gc_GetMetaEvent returned. iDev=0, lEvtType=2, pEvtData=0x87, lEvtDataLen=86719760
190427.061 002 ev TDX_SETHOOK (SetHook Completed)
190427.061 002 ocxev DoFireDialogic(dwIdx=798, 2, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], []) (dwIdx=798)
190427.061 002 ocxev DoFireDialogic completed
190427.061 002 te LINE_CALLSTATE(2, 0x2, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
190427.061 002 ocxfn RecStop(hLine=2, lRecId=0, lParam1=0, lParam2=0, strParam1=, strParam2=)
190427.061 002 dx_stopch call in RecStop
190427.061 002 dx_stopch 2 ok
190427.077 002 ocxfn PlayStop(hLine=2, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
190427.077 002 dx_stopch call in PlayStop
190427.077 002 dx_stopch 2 ok
190428.514 002 ocxfn RingsBeforeAnswer(lLineId=2, lRings=0, lParam1=0, strParam2=)
190429.014 002 lTimer_RingsIgnore_InGuardTimeAfterHangup=0
190440.249 002 ocxfn LineMakeCall(linedev=2, hcall=0, 99338104, callprog=DX_PAMDOPTEN, timeout=29, params:[0,0,cid=,]) chdev=2, dtidev=0
190440.249 002 makecall protocol is: non-ISDN
190440.249 route resources (dxxxB1C2) call
190440.249 dlgc scbus set DevType1 = LSI, sDlgcDevName=dxxxB1C2
190440.249 dlgc this channel does not link to a bus timeslot
190440.264 dx_sethook(2, DX_OFFHOOK) ok
190440.811 002 gc_GetMetaEvent returned. iDev=0, lEvtType=2, pEvtData=0x87, lEvtDataLen=86719760
190440.811 002 ev TDX_SETHOOK (SetHook Completed)
190440.811 002 ocxev DoFireDialogic(dwIdx=800, 2, 135, [TDX_SETHOOK], 0, 0, 0, [DX_OFFHOOK], [CALL_OUTBOUND], []) (dwIdx=800)
190440.811 002 lAtdx_LineSt=0x10:RLS_RING| lAtdx_State=0x1:CS_IDLE
190440.811 002 loop current is present. RLS_LCSENSE flag not set.
190440.811 setting call progress tones according to [C:\Program Files\VoiceGuide\data\ConfigLine.xml] as hli->iReadTonesConfigFromConfigLineXml=1
190440.811 002 ocxev DoFireDialogic completed
190440.811 002 dlgc dx_deltones(2) returned ok (DelTones_SetTones_InitCallProgress)
190440.811 tone an id:FAX:191, f1:1100:110, cad:30:15:0:0, count:0
190440.827 tone description save hli=0x1d2c30, iToneUserID[0]=191 sToneUserName[0]=[FAX]
190440.827 tone an id:DISCONNECT_TAPI1 192 f1:620:200, f2:480:200, cad:30:10:20:10, count:3
190440.827 tone description save hli=0x1d2c30, iToneUserID[1]=192 sToneUserName[1]=[DISCONNECT_TAPI1]
190440.827 tone an id:DISCONNECT_TAPI2:193, f1:550:200, cad:30:10:20:10, count:3
190440.842 tone description save hli=0x1d2c30, iToneUserID[2]=193 sToneUserName[2]=[DISCONNECT_TAPI2]
190440.842 tone ch id:TID_DIAL_LCL:250, f1:340:40, f2:440:40, cad:100:0,0:0, count:1 (arridx=59)
190440.842 tone ch id:TID_DIAL_INTL:251, f1:340:40, f2:440:40, cad:100:0,0:0, count:1 (arridx=60)
190440.842 tone ch id:TID_DIAL_XTRA:252, f1:340:40, f2:440:40, cad:100:0,0:0, count:1 (arridx=61)
190440.842 tone ch id:TID_BUSY1:253, f1:500:200, f2:0:0, cad:55:40,55:40, count:4 (arridx=62)
190440.842 tone ch id:TID_RNGBK1:254, f1:438:138, f2:0:0, cad:130:105,400:200, count:1 (arridx=63)
190440.842 tone ch id:TID_BUSY2:255, f1:500:200, f2:525:175, cad:55:40,55:40, count:4 (arridx=64)
190440.842 tone ch id:TID_DISCONNECT:257, f1:500:200, f2:525:175, cad:55:40,55:40, count:4 (arridx=66)
190440.842 tone ch id:TID_FAX1:258, f1:2150:50, f2:0:0, cad:25:25,0:0, count:1 (arridx=67)
190440.842 tone ch id:TID_FAX2:259, f1:1100:50, f2:0:0, cad:25:25,0:0, count:1 (arridx=68)
190440.874 002 cp_init(2) returned ok (DelTones_SetTones_InitCallProgress)
190440.874 dx_dial([99338104], with call progress) ok
190500.874 002 gc_GetMetaEvent returned. iDev=0, lEvtType=2, pEvtData=0x86, lEvtDataLen=193755944
190500.874 002 ev TDX_CST (CST Event Received)
190500.874 002 ev TDX_CST DE_TONEON cst_data=191
190500.874 002 tone description retrieve hli=0x1d2c30, iToneUserID[0]=191 sToneUserName[0]=[FAX]
190500.874 002 ocxev DoFireDialogic(dwIdx=801, 2, 134, [TDX_CST], 191, 0, 0, [DE_TONEON], [FAX], []) (dwIdx=801)
190500.874 002 ocxev DoFireDialogic completed
190500.889 002 gc_GetMetaEvent returned. iDev=0, lEvtType=2, pEvtData=0x85, lEvtDataLen=86719760
190500.889 002 ev TDX_CALLP (Call Progress Completed)
190500.889 002 TDX_CALLP CR_FAXTONE (called line was answered by a fax machine or a modem (PerfectCall Call Analysis only))
190500.889 002 ocxev DoFireDialogic(dwIdx=802, 2, 133, [TDX_CALLP], 18, 0, 0, [CR_FAXTONE], [], []) (dwIdx=802)
190500.889 002 gc_GetMetaEvent returned. iDev=0, lEvtType=2, pEvtData=0x86, lEvtDataLen=86719760
190500.889 002 ev TDX_CST (CST Event Received)
190500.889 002 ev TDX_CST DE_LCON data=3381
190500.889 002 ocxfn PlayStop(hLine=2, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
190500.889 002 dx_stopch call in PlayStop
190500.889 002 dx_stopch 2 ok
