delesse Report post Posted 11/12/2008 04:10 PM Hello, i use voiceguide 7 with dialogic card D41/JCTLS on win server 2003 my script fonctionne correctly but after 2 or 3 day all lines (4) display ring 2 and stay in this state. after we can't contact the server. with the line status monitor i can hang up the 4 line blocked and the server is ok. i have this problem each week. i join log file at the moment of the lines display ring 2 BUG0826_ktTel.txt BUG0826_0010_vgEngine.txt Regulation.vgs Share this post Link to post
SupportTeam Report post Posted 11/13/2008 03:45 AM Please update to this version: [old link removed]This new version handles the situation at call answer time that we saw happen on your system.If you still have any problems please let us know. Share this post Link to post
delesse Report post Posted 02/01/2009 11:14 AM hello, i installed the update of VG7. I think that fix the problem of crash explain in my last post, but since some $RV_CALLER_ID nor display the number but some digit and #. 105518.732 18 3 rvns add [ScriptPath]{D:\Program Files 2\VoiceGuide\Scripts\RegulationAmbulances\} 105518.732 18 3 rvns add [ScriptsPath]{D:\Program Files 2\VoiceGuide\Scripts\RegulationAmbulances\} 105518.732 18 3 set sScriptToRunOnHangup=[] in StartLoadedVgs 105518.732 18 3 rv add [$RV_STARTTIME]{2009-02-01 10:55:18} 105518.732 18 3 rv add [$RV_DEVICEID]{3} 105518.732 18 3 rv add [DlgcVoice]{dxxxB1C2} 105518.732 18 3 rv add [DlgcNetwork]{dxxxB1C2} 105518.732 18 3 rv add [$RV_CIDNAME]{} 105518.732 18 3 rvns add [PathApp]{D:\PROGRAM FILES 2\VOICEGUIDE\} 105518.732 18 3 rvns add [ScriptsPath]{D:\Program Files 2\VoiceGuide\Scripts\RegulationAmbulances\} 105518.732 18 3 [u] rv add [$RV_CIDNUMBER]{3#}[/u] 120420.911 18 3 rvns add [ScriptsPath]{D:\Program Files 2\VoiceGuide\Scripts\RegulationAmbulances\} 120420.911 18 3 set sScriptToRunOnHangup=[] in StartLoadedVgs 120420.911 18 3 rv add [$RV_STARTTIME]{2009-02-01 12:04:20} 120420.911 18 3 rv add [$RV_DEVICEID]{3} 120420.911 18 3 rv add [DlgcVoice]{dxxxB1C2} 120420.911 18 3 rv add [DlgcNetwork]{dxxxB1C2} 120420.911 18 3 rv add [$RV_CIDNAME]{} 120420.911 18 3 rvns add [PathApp]{D:\PROGRAM FILES 2\VOICEGUIDE\} 120420.911 18 3 rvns add [ScriptsPath]{D:\Program Files 2\VoiceGuide\Scripts\RegulationAmbulances\} 120420.911 18 3 rv add [$RV_CIDNUMBER]{3#5#5#1#6#} thank you for your help Share this post Link to post
SupportTeam Report post Posted 02/01/2009 07:12 PM Please post the whole ktTel and vgEngine traces so that we can fully see what is happening on the system. Share this post Link to post
delesse Report post Posted 02/02/2009 03:41 PM this is the kttel file 0202_ktTel.txt Share this post Link to post
SupportTeam Report post Posted 02/03/2009 07:35 AM Please update system to this release of VoiceGuide:[old link removed] and post ktTel traces (.ZIped) if CallerID is still not reported properly. Share this post Link to post
delesse Report post Posted 02/06/2009 09:17 PM After the VoiceGuide_7.0.9.....exe installed, i can't start the service, an error is displayed. Share this post Link to post
SupportTeam Report post Posted 02/07/2009 12:44 AM It's possible that you do not have certain pre-requisite files on your system. Please try with this version: [old link removed] this updated version has the newly required VC++ redistributable files as well. If you still have problems please describe what error you are seeing. Share this post Link to post
delesse Report post Posted 02/08/2009 03:38 PM Hello, that seem to be good. The service started, The script is OK but i am in evaluation mode (to be restared each hour) i registered voiceguide with my key (the ID is the same); i restart the service, but the line monitor status display: EVALUATION (needs restarting every hour, 30 lines, HK******. ps : i buy only 4 lines thanks Share this post Link to post
SupportTeam Report post Posted 02/08/2009 07:32 PM Please contact sales@voiceguide.com regarding any registration/license questions/issues. Share this post Link to post
