Uninstall Dailogic Drivers And Software
I am trying to install drivers and software for a D4PCIUFWEU card but when I run the setup it tells me the software is already installed and i will need to uninstall it from add remove programs. When I go to add remove programs there is no dialogic programs to uninstall. Any ideas?
Jas
Hard to say what could be the problem. Maybe the drivers are labeled as "Intel Dialogic" instead in the installed programs list?
You could just try deleting the Dialogic directory in the "Program Files", but that may leave behind some Registry entries.
Probably best to just format the drive and install Windows and then install the drivers.
