Guest newpop1 Report post Posted 11/24/2008 05:35 PM Hello, we have a 23 Line Dialogic-PRI system with VG 7 Ent + dialer. We are putting together a backup server in case the original server crashes, we can do a hot swap of the PRI T1 line to the new server that matches the main server hardware specs. We have an issue with VG due to licensing. Some questions: 1) If the main server goes down, how do we install our VG 7 licenses in the backup server so it goes online? 2) Are we forced to purchase another 23 licenses to just sit there? Thank You Share this post Link to post
SupportTeam Report post Posted 11/24/2008 07:07 PM The licenses are tied to the Dialogic card, so the license will work in whatever machine that Dialogic card is transferred to. If you want to setup a true ready-to-use-immediately backup server with another T1 Dialogic card in it then you will need to purchase another license - just like you would need to purchase another server, another Dialogic card, another copy of Windows etc. Share this post Link to post
Guest newpop1 Report post Posted 11/26/2008 06:19 PM We do have a complete set of new hardware. So we are ok if everything fails except the Dialogic card. If the Dialogic card fails and we need to install a new Dialogic card, how do we go about installing it in the new server? Thank You Share this post Link to post
SupportTeam Report post Posted 11/26/2008 09:07 PM Dialogic cards very rarely fail. What is the current approach on your side if the Dialogic card fails? Exchange the card under warranty? Please contact sales@voiceguide.com to discuss with whom you'd be doing the Dialogic warranty exchange and VoiceGuide license changes associated with warranty exchanges. Share this post Link to post
