Using Excel
We have recieved may questions about retrieving data from Excel. Below is an example of the VB Script which can be used to write data into Excel and then read back results. The script the below just needs to be copied into a VoiceGuide "Run VBScript" module. If anyone has any questions about it please post them here...
'takes 3 Result Variable inputs,
'writes the inputs into an Excel spreadsheet,
'reads the results calculated by Excel in other cells
'returns results back to VoiceGuide.
Dim excel, workbook, sheet
Dim Result1 , Result2 , Result3 , sReturnedRVs
Set excel = CreateObject("Excel.Application")
Set workbook = excel.Workbooks.Open("C:\SomeSpreadsheet.xls")
workbook.Sheets("Sheet1").Select
workbook.ActiveSheet.Cells(2, 2).Value = $RV[CallerInput1] 'cell B2
workbook.ActiveSheet.Cells(2, 3).Value = $RV[CallerInput2] 'cell C2
workbook.ActiveSheet.Cells(2, 4).Value = $RV[CallerInput3] 'cell D2
'every time new values are entered Excel recalculates any formulas,
'allowing us to read data from formula cells at any time...
Result1 = Abs(Cint(workbook.ActiveSheet.Cells(2, 22).Value)) 'cell V2
Result2 = Abs(Cint(workbook.ActiveSheet.Cells(2, 15).Value)) 'cell O2
Result3 = Abs(Cint(workbook.ActiveSheet.Cells(2, 24).Value)) 'cell X2
sReturnedRVs = "[Result1]{" & Result1 & "}[Result2]{" & Result2 & "}[Result3]{" & Result3 & "}"
iRet = WriteResultFile(sReturnedRVs)
'the 3 result varaibles can now be accessed in the script using:
'$RV[Result1] $RV[Result2] $RV[Result3]
'msgbox sReturnedRVs
workbook.close False
excel.quit
set excel = Nothing
set workbook = Nothing
function WriteResultFile(strResult)
const ForReading=1, ForWriting=2, ForAppending=8
Dim filename, fso, ts, outdata, outdata2, outdata3
filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
set ts = fso.OpenTextFile(filename, ForWriting, True)
ts.WriteLine(strResult)
ts.Close
WriteResultFile = 0
end function
