clesio Report post Posted 11/30/2008 11:58 AM Dear Gentlemen, We company's MOBLINK mobile solutions installed in Brazil, my name is Clésio. Install the version 6.0.3386 Working Trial Version, but when we are modeling our application, using the Script Designer, it does not run script written by more than an object(module). Example: If you write an object in script "Capture Entered Number" and another script object in the "Run VB Script," he runs just one of them. When this script runs... "Capture Entered Number" Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 set fso = CreateObject("Scripting.FileSystemObject") set tsFile = fso.OpenTextFile("c:\output1.txt", ForAppending, True) tsFile.WriteLine "FILE LOGIN 1: $RV[PEDE LOGIN]" tsFile.Close set tsFile = Nothing set fso = Nothing This one does not run... Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 set fso = CreateObject("Scripting.FileSystemObject") set tsFile = fso.OpenTextFile("c:\output2.txt", ForAppending, True) tsFile.WriteLine "FILE LOGIN 2: $RV[PEDE LOGIN]" tsFile.Close set tsFile = Nothing set fso = Nothing Only a script runs at a time when we use two scripts at the same time, he always runs the first. We'd like to know whether the registered version does not have this problem. MOBLINK mobile solutions Thank you. Clésio de Miranda - Systems Analyst. clesio@moblink.com.br Share this post Link to post
SupportTeam Report post Posted 11/30/2008 07:18 PM Could you please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened. Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 CallLoader=0 VoicemailManager=0 EmailSender=0 ktTel=0 ktTts=0 Then restart VG and make a test call which demonstrates the problem. Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
